they should arrive today. Getting the same exact pad type as I currently have. Ferodo CP911*'s for my cast iron front rotors. Is there any need to do any cleaning other than normal cleaning of the rotors with brake cleaner? Meaning scuffing the rotors or using a Scotchbrite pad. I need to look up how to "bed" the pads in. My track day I guess can be used for that. Also what type of cleaning do you do of the calipers? I assume the main areas to clean maybe are hte piston and piston bore? I'll look in the Haynes and the service manual tonight but I remember reading what some people so is put a light coating of brake fluid or something in the bore. Also I seem to remember something about not cleaning the piston with brake cleaner. Just looking to see what's the correct thing
