Hello Team,
Just in the process of re-shimming the gearbox of my 94 900SS and need some advice on tolerances. Both the Haynes manual and Ducati service manual list a maximum end-float of 0.15mm for the main and lay shafts. What would be considered a reasonable minimum?
Thanks Brad, much appreciated. I currently have 0.05 on the main shaft (check) and 0.09 on the changer drum - does that sound too tight? Still working on the lay-shaft.
