Any standard 80mm size gauge should fit in theory, but whether the mounting bolts line up is another question altogether.
I know they are the same diameter as the gauges on my Thruxton which are 80mm.
Which gauge are you looking to replace? SPA makes a sweet tach that has a water temp display built in if you wanted to pull that gauge too.
