I have a 04 800ss. Was a salvage/ theft recovery bike that needed new ignition, gauges, chip. Instead of spending the $3700 in parts from local dealer I found a set on ebay for $500. Great deal only problem is they were from a 04 s2r 800. Bike runs good I'm just concerned with any problems this setup might cause. Anyone know if they are compatible or know of any other modifications I might need to make to have these work? Also if I decide to upgrade the exhaust what should I get s2r or 800ss chip, or will a power commander do the job. I know it depends on the exhaust I go with but still confused. Almost forgot the tach works fine but speedo is off by about 25 mph. Any ideas?
the S2R engine and the SS800 engine are the same with every part
as far as i know, so the stock mapping should work fine.
i would get the exhaust and a power commander, or get the exhaust
first and check out what the mixture is like.
could be that another map can be flashed to your existing ecu,
but i am not sure.
the speedometer is working with the rear brake disc bolts, seems as
if both bikes have a different number, there is a reasonable priced
electronic gadged at hand, to help you with this, i just forgot the
name...it is 5.20 am anyway.
:think:
edith: name could be speedo healer.
thanks for the help. I'll look into the speedo healer. I was thinking termi pipes that come with ecu, or any pipes for that matter. Just want to make sure that i get right one, but some slip-ons with a pc could do the trick. How's the riding weather in germany? Good I hope. Thanks again from Ohio, only midnight here. :D
riding weather would be okay, but bike has no legal plate yet,
i read my mantra and try to stay calm.
:think:
