I've read the post on the tank issues. Having a new GT, trying to confirm if there are two brackets. One on each side. The reason I ask is becasue I can lift up my right side (dealer said it was fine) and the left side is solid. Should the right side also be solid or is it suppose to be flexible?
Ryan
I have a new '09 Sport1K. Just did the 600mi service. The left side is in tight, the right side was just barely in the bracket. I also had the right side starter button touch the tank @ full right steering lock. It was not this way @ 0 miles & I did not adjust the steering stops, the tank is going wide-right.
They should both be in the brackets. If you look straight down @ your ingnition key the half-circle space should be even (or close to it) around, mine opened up. The dealer put in for a replacement, just waiting on the new tank.
I can see a little room OK, but if you loose steering -lock or the tank is about to fall out, have dealer order a warrenty replacement.
