1 - 6 of 6 Posts
06 ST3s. I smell a small to moderate level of gasoline fumes from my filler when I ride or just sitting atop of bike in garage. I wonder if replacing the rubber ring around the filler flap/cap is possible. I don't see a Ducati part for it but has anyone tried to procure one elsewhere like McMaster?
After finding "Similar Threads," pressed the gas cap down to make sure was closed, no click so I have been closing it correctly. Hose overflow is connected inside/underneath fill hole. But, compared to tiger 1050, the ring rubber is hard & not soft/compliant. It's not the sliding spring loaded gasket, so it's not a sticking issue. I suspect poor seal b/c hardened gasket/rubber ring.
I suspect the gasket since pushing downward on the cap results in about 1-2 mm of vertical play. I will try the silicone treatment.
If your overflow tube has a small can in it, that’s a one way valve. Clean it and make sure it rattles.
geez, with all the smoke here in the sf bay area, it no longer is a noticeable garage smell. no outdoor activity, no riding, poor dog has even started chewing on furniture. cabin fever fido & i.
Before replacing anything, check that it is not leaking at the hinge at the back of the tank. Mine started as a very slow weep that only showed as a gasoline smell for the first few months. As it got worse, it finally started to drip onto the floor.
1 - 6 of 6 Posts
