43 in mineI didn't buy the bike expecting 50 mpg but -
2006 ST3, termi exhaust, DP ECU, and air box mod and I'm getting 40 mpg at 65 mph, 4000 rpm. 11k miles.
Normal?
Thanks.
Not overly excessive but how long have you owned the bike for , you can take a while to use the engine without excessively lugging the engine taking advantage of the torque but large throttle openings mean low higher fuel consumption. I very rarely see less than upper 40's but that is at 80 mph and often two-up , it was lower in the early days when I did not allow her to rev out freely on lower throttle openings...........Imperial gallons over here of courseI didn't buy the bike expecting 50 mpg but -
Normal?
Thanks.
Agree with this... but being new to an ST 4 it would be nice to know the rangeI own a Ducati,,,,,,,,,,,,,,,I dont care how much she drinks that high 90'sh-Shell gas,Long as she's happy,,,,,,,,,,,,,,,,,
An you're doing better than me as I can only manage 33-34 mpg but then I do ride it like I stole it, on my commute to work which is fast a roads 30 miles each way. ST2 13k miles carbon can co. pipe an chipped with open air box with K&N filter.Well don't be unhappy - yer all doing better than me <s>...
'98 ST2, 27k miles, Fast by Ferracci pipes and chip - and I'm getting around 37 mpg - commuting 30 minutes to work, mostly on the highway; evening rides on the back roads, a few weekend trips
Now yer talkin' Tim. I had one of those once, it used to run for weeks on a tank of gasGet yourself a honda CG125 if you want mpg.
The only way to accurately check is the old style , full take , zero trip , run until ready to fill again , fill tank to same place and check milaege tehn do the maths.Thanks for the replies; the mpg I stated was off the bikes computer. I know the speedo is off (70 on the speedo is about 64 on the GPS). I guess that's good to avoid speeding tickets. If the speedo is off, I'm sure the computer is off as well.
Ride safe,
Curt
The computer on mine is off my 8-10 mpg. It displays 42-48 mpg for most riding for me, on a long trip i did in April (1200 miles, 3 days) i figured the actual mileage as stated above, 33mpg was it.Thanks for the replies; the mpg I stated was off the bikes computer. I know the speedo is off (70 on the speedo is about 64 on the GPS). I guess that's good to avoid speeding tickets. If the speedo is off, I'm sure the computer is off as well.
Ride safe,
Curt
...I can't say that I've ever been able to check my 07 ST3 at anything but about 85 mph....most recently I put 2400 miles between Kansas City and Austin, TX...I didn't buy the bike expecting 50 mpg but -
Normal?
Thanks.
