1 - 3 of 3 Posts
Hello,
Does anyone know the Gap Spec for the crank sensor on a 2002 998????
Is there even a spec????
Fit a feeler gauge into the hole and measure the air gap between the sensor and the timing lay grar teeth. Check that air gap is 0.65-0.70mm if value is outside specified limits, remove sensor and change seal thickness.
Thank you!!!!
1 - 3 of 3 Posts
