1 - 2 of 2 Posts
Ok so I jumped my 97 916 off w/ a car and had it running for a minute then it completly shut off,after investigating the fuse in the tail section keeps blowing every time I push the run switch. Keeping my fuel pump and starter from engaging
grand poobah
Lets start with the jumping it off the car issue. Did you replace the battery and still have this problem? More than likely the battery has a dead cell causing the relay idenitfy a low voltage and to kick out. The fuse blowing is more than likely a short somewhere. As it your first post, finding faults is a time consuming process. I would reccomend going through each connector and looking for a loose one or a burnt one. Search the hall of wisdom for the very common voltage regulator connector burn out, there are wxcellent reccomendations for mods of this connector there. Good luck. Brad
1 - 2 of 2 Posts
