1 - 9 of 9 Posts
#3 Was told to expect it mid month or so.
You bring up an interesting point...
I think with the open system instead of the closed loop system on the stock headers that there would be no flat spot even without the new fix.
Ken
Does the Termi slip-on kit keep the closed loop system intact? I wonder if the fueling fix that will be applied to the stock SF's will need to be applied to the DP ECU?
The slip ons still utilize a closed loop system. I would say that the fix works with the slip ons as there are people on the forum that had the slip ons on the bike and them got the "fix" and the problem is corrected.
Ken
Ken
This doesn't sound right to me. The non-homologated (non-street-legal), carbon slipons do not have a catalytic converter, and do not therefore need closed-loop control. They are referred to in the literature as "racing" equipment, and the corresponding ECU is referred to the same way. This implies that there is no use of closed loop control to maintain stoichiometric fuel mixture, as would be needed to feed the catalytic converter located in the stock muffler, and also in the homologated (street-legal) titanium slipons (which include a catalytic converter, as mentioned in the description in the Accessories catalog). There is a new ECU with the titanium, homologated slipons, but it probably just takes care of a remap for increased flow with the new exhaust.
I'm not sure why people with carbon slipons and the racing ECU would be getting the same reflash of their ECU as people with the stock exhaust and ECU. That would make no sense, for the above reasons.
1 - 9 of 9 Posts
