1 - 10 of 10 Posts
Hi ~~ guys ~
When you change your exhaust to a
full system~ there has to be a lot of follow ups ~ such as
ECU, Air filters ~
I understand that when you do not want to change your ECU , thats
when you install Power Commander, Rapid bike , Nemisess these kind
of things with your exhaust maps.
Then ~ when do you do TPS reset ??? Do you still need to perform
TPS reset , even though you install power commander or DP Ecu ?????
I looked up the Hall of fame and couldnt get the answer ~~!!
Advice please ~!!! enjoy the photo ~
OK ~ so, all I have to do with the Power commander is down load the map into the
module and connect it to the bike ! right???? Thank you for the input
Desmoworks ~!!!
Which bike do you have? If it is a bike that uses an O2 sensor the Power Commander will not be able to map the closed loop areas which is roughly under 5K rpm and 20% throttle.
But yeah, install the power commander, set the TPS on the power commander if it isn't correct to begin with then load the map and enjoy.
Discussion Starter · #10 ·
I have 2003 999s ~ so I belive Power Commander will not be able to make
any changes to the below 4000 rpm area ~~!! But still it should be better
than not having one right???????
1 - 10 of 10 Posts
