The slip-on option is gonna be cheaper, and will probably flow better than the standard mufflers... BUT - the full system flows MUCH better than the standard headers. I went with a Sil Moto Italia full system when I upgraded my 900...
However, if you're going to go that path, you may also want to consider a set of 41mm Keihin FCR carbs - that's if yours has carbs...? Otherwise you'll need a powercommander or chip for the ECU.
One of these cases where you should balance both the intake and exhaust improvements.
Here's a pic of the two systems...
