1 - 2 of 2 Posts
Sup fellas. I did a lot of searching but can't seem to find a clear cut answer. I plan on purchasing the SC project Full exhaust system 2-1 with Conic silencer. My question is, is it a MUST that I get the ECU flashed? I will be leaving the stock air box. Bike is a 16 HYM 939
I'm sure someone will pipe in (tee hee) with a model-specific answer but generally, a full system will need an ECU reflash because you're taking away the O2 sensors and exhaust flapper valve. It's probably also a big enough improvement in breathing to need a richer fuel map.
1 - 2 of 2 Posts
