Anyone have a link to, or the dimensions of the grommet that goes into the rear of the fuel tank? Mine got munged. Thanks!!
Presume you mean the one in the bolthole for the tank? If so it's part # 70010191A 'Rear Tank Rubber' I paid £1.16 (approx $1.75) for one back in February.
Since replacing the airbox seal my tank is a tighter fit and it does chew this rubber up some, but check that the 'top hat' washer is in there because if not it will eat through the grommet super-quickly - don't ask how I know this. :rolleyes:
Thanks!
Yeah, mine didn't have the washer insert....much appreciated!
A new airbox seal will cause the tank to sit higher, but the threaded hole for the hold down is thru, not blind, so a 10mm longer bolt will do the trick nicely.
