61 - 80 of 80 Posts
1993 750SS
Resurrecting this thread...
I found some metric fuel line/hose locally that measures 7mm I.D. x 11mm O.D.
The stock stuff is 7mm I.D. x 13mm O.D.
Do I risk cracking the plastic connectors with clamps, if I go with the smaller size?
The ancient plastic connectors will break if you look at them wrong, I've found stainless steel ones on eBay to replace them, more U-shaped rather than Y for the return to tank line. They make brass ones too.
Is that the plastic connector you are concerned about? Or the one on the carbs or in the tank on the fuel pump and filter? In any case, the OD difference is not significant even if you are using the crimp type clamps properly applied with the special tool.
1993 750SS
Yes, the Y-connector is the one I'm most concerned about since it's unobtanium. And I'm planning on using those crimp type clamps, so I don't want to inadvertently crack anything. I just finished rebuilding the carbs, so I'm replacing the feed line that runs from the Y-connector to the T-connector between the carbs. I need to do a once over on all the hoses though, to see what needs replacing.
Depending on your routing plan, see if you can put a small clear fuel filter after the Y and maybe a shutoff valve too?
1993 750SS
I've seen a few guys do that mod, but I was reluctant to do it myself because I wanted to keep the bike looking original. But it is a good idea, and it beats raising the tank to turn off the fuel.
I have the FCR41's and after an incident with a Kawasaki ZZR600 that dumped about 1.5 liters of fuel into the crankcase I installed this shutoff valve between the Y-junction and the carburetors. It's easy to reach and operate. In the "off" position here in the photo, rotated a quarter turn to be inline with the fuel lines is "on". It's stuck to the frame with a rectangular piece of rubber cushioning and ziptied in place. You'd never know it was there unless you looked down between the frame and right side fairing.
1009934
On the positive side, running a few gallons of fuel through my crankcase made the shifting easier once I had changed the oil twice. Cleaned the insides very well.
A member here made up a 3D printer file to make a very sano looking clamp for the frame at that location and for the type of shutoff that skowinski shows in his pic.
1993 750SS
That valve blends in nicely. Is this the same one?
It looks like fuel may have gotten into my crankcase too. I need to drain it to be sure. You had to change yours twice and install the shutoff valve before the oil stayed clean?
I'll check out that 3D printer file 👍🏼
1993 750SS
@RockAZ
Is this what you were talking about?
1993 750SS
Cool. Looks the business. Would you mind sharing the .pdf?
It is a file to print on a 3d printer, do you have access to one?
PM mzrhayes on this forum, he made the original .stl file and there are some other details you need to know on how/what to print.
1993 750SS
I would have to send it out for printing. I don't have one. Kind of just wanted to check out the plans.
I do have some aluminum sheet metal though, so I might just make a bracket similar to @rennsportmotorrad's.
The 20kb plans look like this:
01100111 00110001 00001111 00000101 010010000 10010011
Nothing to see without the 3D software, the post you linked has the 3D software view and a pic of one installed after printing.
1993 750SS
I was under the impression that the .pdf was a solidworks or revit drawing of the orthographic views with dimensions.
Well, it printed fine as a * .stl file, which requires a program to look at it.....
Actually I think that is the one. A buddy who owns a Beechcraft Baron directed me to that company years ago, they have all kinds of good stuff that transfers from aircraft to motorbikes.
I'm a pilot and the airplane part "surtax" is only slightly higher than the Ducati "surtax"....
But Aircraft Spruce does have a nice selection of goodies.
1993 750SS
They sure do. I went ahead and ordered a shutoff valve from those guys. So much for keeping the bike looking original 😎
But after hearing from you guys and seeing some of your setups - that look good - it only made sense.
61 - 80 of 80 Posts
