Hi,
My fried just tried to remove the gas tank from his 01 700cc Monster. It's the metal gas tank. While doing so, he ripped the plug off. I had it spliced back together but the pump does not turn on. I know that the epoxy sender under the tank is a real pain, but I wanted to see if the pump is even getting power. Started to take the cap apart and lo and behold, the damn thing is soldered shut, right where the set screws would be.
What do I do at this point? I don't feel right about cutting it out and new tank is half the price of used monster...
That’s just the fuel level sensor. It’s a carb motor? Fuel pump is vacuum mounted to the frame on the he rh side
