1 - 8 of 8 Posts
fuel pump is spitting fuel out the little hole next to the nipple for the fuel line. has new fuel lines. any answers?
Come in Spinner :)
Far as I know that's a pump relief valve so I'd check the main pressure regulator isn't stuck closed.
Yes, when I had a blockage at the tank fitting (due to expanding internal 'O' ring in the fitting closing off the fuel flow) it spat loads out of there due to having nowhere else to go.
replaced the regulator last night still have the same problem. going to assume its the pump. it get 3 bars of pressure though.
Dumb question, do you have it connected to a circuit (ie throttle body with the return) or are you bench testing it with only the outlet connected (ie straight to a pressure gauge)? If you were running it without a return I'd imagine it would back up when it pressures up.
Discussion Starter #7
No, its in the bike . Put all new neoprene fuel lines in 2 days ago. New fuel disconnects good filter ect. No obstructions in the fuel lines.
Discussion Starter #8
changed the pump, lines, regulator, nothhing no change. turns out it was thd air/fuel separator was bad.problem ffixed now.
1 - 8 of 8 Posts
