1 - 10 of 10 Posts
I see a number of alternate parts posted for the fuel pump relay. It was a Bosch, originally (28740402A), superseded by a Hella part (28740403A).
However, none of the alternate parts I've found actually have the waterproof shrouding and the part for the clip to secure it.
What do you folks do when using the alternate parts to waterproof and maintain a solid connection? Or no big deal?
TIA
Super Moderator
I haven't swapped mine out yet...but i do carry spares of the alternate part variety. I've never noticed the relays getting wet up under the seat. I don't think it's a big deal.
I use these: Ebay 302708108260
Not sure moisture would be a problem but you can always add some rtv around the relay case and base to seal it and some dielectric grease to the terminals before plugging it in.
Right --those are similar to what I was referring to; they don't have the waterproof shrouding, nor the attachment for the securing clip.
They are sealed at the base. Not sure what you want yours to look like; post a picture?
Discussion Starter · #8 ·
The stock part looks like this: https://www.stein-dinse.biz/product_info.php?products_id=182654
The stock Ducati part has a shroud/skirt/collar that couples with the plug to make a dust-proof and waterproof seal. There's also a clip part on the shroud that secures the connection.
Just curious what folks do, if anything, with the non-OE ones without the added protection.
Discussion Starter · #10 ·
I replaced mine with epoxy sealed relays. Still good after 2 1/2 years.
Here is the thread covering this discussion back in 2017: https://www.ducati.ms/forums/40-sport-touring/690369-ignition-relay-st4s.html
Steve
Thanks for the link. The starter relay on my '99 is Bitron, made in Italy (B047 PA66-GF30) with a different layout. The newer Siemens and Tyco replacements definitely won't work for me. I'm fairly certain my starter relay is still good though.
I ordered up a pair of the OE fuel pump relays and will hopefully be good to go.
1 - 10 of 10 Posts
