Can someone please confirm key they fuel pump primes when you turn the key to ON, but with the ENGINE STOP/KILL in the STOP or OFF position.
My 999R only primes when I have my ENGINE STOP is in the RUN position and turn key on. If it's in the STOP position and I turn the key on it doesn't prime. Even if I then turn the ENGINE STOP switch to RUN after the key is turned on, the fuel pump doesn't prime.
I switched to a Microtec ECU and could swear it used to prime either way.
