Hoping someone can guide me on this. My bike was losing power at high RPMS and spraying fuel out of the top of the cap. When I took the cap off and the fuel assembly out I replced all of the hoses and the fuel filter, put it back together and started it up. It starts fine, but it is still sprying fuel all over the inside of the tank. The fuel actually sprays from the back of the tank across the fueling hole, I can see it spray across with a flashlight, but cant see where it is spraying from. Now the kicker, when I disoconnect the yellow fuel line and start it up with just the black line connected the sprayng ceases, has anyone seen this before, I am thinking the injector to the yellow fuel line is clogged causing the fuel to spray back in the tank. ?Any ideas?
