1 - 7 of 7 Posts
Does anyone know if there is a difference in fit and function, between the black and white, feed and return fuel line connectors apart from price and colour? I have broken the white one and its a lot more expensive than the black connector.
They are exactly the same and are only colour coded so that you plug them in the same every time, however even that doesn't matter as although one is flow 'M' (mandata) and the other is retrun 'R' (ritorno) it is simply a loop feeding the injectors and makes no difference if you reverse the fittings.
How many connectors does a 998 take? Easy install?
Flash
Flash
2 of each (Male/Female) and easy enough to fit, although to fit the female parts to the tank you will need to remove the springs/catches to get a socket onto it so watch that the spring doesn't fly across your garage when you're removing it (don't ask how I know). ;)
1 - 7 of 7 Posts
