fuel line disconnects
1814 8
ok, i have an extra tank and set of fairings. i was going to paint them black. the fariings change quick enough, but what about the tank? are the stock disconnects a real pain? should i buy a set of metal ones off ebay? somewhere else? thanks in advance.
1 - 9 of 9 Posts
I know people complain about the plastic ones but I haven't had any issues with them so far.
Does your new gas tank have the complete fuel pump/filter assembly too already? That thing is a pain to remove and replace. It's not something I enjoy working on personally.
If you're talking about where the fuel lines plug into the bottom of the tank, they are super easy. Just push the tab while pulling on the line and they should just pop right off. They are color coded too.
Are they one way self closing? Or does gas come out when you disconnect?
The QD's are one way [provided they are functioning properly]
McMaster Carr sells the CPC disconnects for a fair price
I generally grease the o-ring each time before I reinsert the male end. It just makes it go in easier with less risk of tearing the ring [the main reason for leaks]
1 - 9 of 9 Posts
