1 - 3 of 3 Posts
Mayor of Simpleton
Anyone know the fuel injector specs for the 996cc ST4S? What flow rate and at what fuel pressure?
I'm probably going to have to get something that flows just a bit more for the built motor.
Excel Addict
2001 900SSie
A quick search shows it to be the Weber "green top" IW 031
The specs are almost at the bottom of this page. Stan Weiss' - Electronic Fuel Injector (EFI) Flow Data Table
270.1 cc per minute at 3 bar. 25.7 lbs per hour at 43.5 PSI.
I think your ECU is a 59M which can't be remapped with Guzzi Diag. I don't know if JPdiag can write a new map.
Maybe a Power Commander or a Dobeck piggyback to change fuelling if there are versions available for your bike.
Reactions: nine16
Mayor of Simpleton
Thanks, that looks like the info I need. Mapping won't be a problem--I'll be using a Microtec.
1 - 3 of 3 Posts
