I looked it up and I searched on here. Is there not an interval for changing the fuel filter? It looks like its in the tank but I don't even see a procedure for changing it in the service manual. Am I missing something...on a fuel injected engine?
Discussion Starter · #2 ·
No one?
Crappy copy and paste job but I saw nothing in the scheduled maintenance to change the fuel filter nor a procedure.
3 - Routine maintenance table
Scheduled maintenance chart: operations to be performed by the dealer
List of operations and type of intervention
[set mileage (km/mi) or time interval *] Km. x1000 1 12 24 36 48 60
mi. x1000 0.6 7.5 15 22.5 30 37.5
Months 6 12 24 36 48 60
Changing engine oil • • • • • •
Changing engine oil filter • • • • • •
Cleaning engine oil intake filter •
Checking engine oil pressure • •
Checking and/or adjusting valve clearance (1) • • • • •
Checking timing belt tension (1) • • •
Changing timing belts • •
Checking and cleaning spark plugs. Change them, if necessary • •
Checking and cleaning air filter (1) • • •
Changing air filter • •
Checking throttle body synchronization and idling (1) • • • • •
Checking brake and clutch fluid level • • • • • •
Changing clutch and brake fluid •
Checking and adjusting brake and clutch controls • • • • •
Checking/lubricating throttle/choke control • • • • •
Checking tyres wear and pressure • • • • • •
Checking brake pads. Change them, if necessary • • • • • •
Checking steering bearings • •
Checking chain tension, alignment and lubrication • • • • • •
Checking clutch plates pack. Change, if necessary (1) • • • • •
Checking rear wheel flexible coupling • •
Checking wheel hub bearings • •
Checking indicators and lighting devices • • • • •
Checking engine-to-frame screw nuts tightening • • • • •
Checking side stand • • • • •
Checking front wheel nut tightening • • • • •
Checking rear wheel nut tightening • • • • •
Checking external fuel lines • • • • •
Changing front fork fluid •
Checking front fork and rear shock for leakage • • • • •
Checking front sprocket fastening • • • • •
General lubrication and greasing • • • • •
Check and charge battery • • • • •
Vehicle test ride • • • • • •
Overall cleaning • • • • •
fuel filter
my dealer changed mine at the 7500 mile service. so i changed it again at the 15000 mile service, witch i did my self and saved a whole lot of cash. its right on the fuel pump. just drain the tank and remove the fuel pump. its pretty straight forward. be sure to clean and lube the big o ring on the fuel pump when putting it back on the tank. the dealer did not do this on mine when they changed it and it leaked. thats how i found out they changed it. and dont go crazy when torquing down the fuel pump bolts. the shop manual calls for 5nm's on these. i remember reading a post were someone spun the insert when torqing down the bolts.
Good info to know. Thanks. Still think that it's odd that there isn't a specified interval for it in the owner/service manual.
