1 - 2 of 2 Posts
Brand new without box, SuperSprox rear sprocket to fit all 1098/1098R/1198 bikes.
This is a 41 tooth 525 chain sprocket, which I believe is a necessary upgrade for these bikes.
Pulls much better in all gears with little compromise to top speed, which you rarely hit anyway.
Stock rear sprocket is 39 tooth/525 chain - steel. This SuperSprox has a aluminum carrier with a steel chain ring riveted to the carrier.
Will shed some weight and last a long time. Will not fit the 848 bikes with 5 hole carriers.
Paid $165.00 /new - Selling for $115.00 /new with shipping included to all 50 US states.
Discussion Starter #2
Typo correction: 1098/1198 stock gearing is 38 tooth rear and 15 tooth front.
Adding this 41 tooth rear (plus 3 teeth) would be the equivalent of dropping to a 14 tooth sprocket up front.
1 - 2 of 2 Posts
