1 - 20 of 21 Posts
Discussion Starter #2
For Sale: 996 Race Wiring Harness
For sale: 996 race wiring harness
This is a wiring harness with all the unnecessary street wiring removed.
Does not have a fan provision
Requires front mount ECU
Uses a toggle switch for on/off
This was done by Bruce Myers of BCM fame a couple of years ago
$200 shipped to CONUSA
For Sale: Akrapovic 996 EVO 45-60mm Full System
For Sale: 996 Akrapovic EVO 45-60mm Full System.
It's a 45 - 60mm tapered system. Header pipes are 45MM, mid-pipe is 50mm and the mufflers are 60mm
**This is considerd the HOLY GRAIL of exhausts for the 996.**
System has been installed and has less than 30 minutes run time.
$2,200 shipped in the CONUSA
If it doesn't sell, I'm going to cut it up and use it on the 1198
air box and wiring
hello
is the air box available ?
is the race wiring for 4 injectors or 6 injectors throttle bodyes ? at which you have used it ? 60 m throttles ?
macci
Discussion Starter #17
Airbox, tubes, under seat breather and collant bottle are sold
Still have Akrapovic EVO 45-60mm full system $1,800 shipped
Clutch Slave $75 shipped
Billet brake caliper bracket and rotor $75 each shipped
Race wiring harness $200 shipped
1 - 20 of 21 Posts
