1 - 8 of 8 Posts
Mayor of Simpleton
Yellow painted track fairings $250
Ilmberger carbon fiber intake runners--top quality and used the stock filters, but badly water-spotted on the top side. One signal mount has been repaired but it’s not too visible with the signal in place. If you have the patience to try to rehab these or just want to paint them: $175
Discaciatti cast iron full-floating front discs $325
Normal front discs (some wear on the gold centers) $75
Brembo gold line, 40mm mount calipers (with pads) $175
Brembo 4 pad calipers (with pads) $240
Gold headlight bucket and mirror supports $120
Master cylinders and other parts available as well. PM with requests.
Mayor of Simpleton
Track fairings (stickers are removable)
Mayor of Simpleton
Forgot I also had CarboTech carbon fiber intakes. These don't have the internal filter provisions but are in very nice shape without of the fading/water spotting. $350
I also have some photos of the headlight bucket/mirror supports (no infamous chips on the bottoms!) and the Discacciatis (5.60mm, btw).
Mayor of Simpleton
Ilmberger intakes sold.
Mayor of Simpleton
The standard front discs are sold. (Discacciati still available, as are most of the other parts.)
Is that a hole in the bottom of the belly pan on the track plastics or a black sticker/paint? Thanks
Mayor of Simpleton
Discussion Starter #8
That's a hole.
1 - 8 of 8 Posts
