A work of art. The most beautiful bike I've ever owned. Rides like a dream.
Concours D'elegance Best in Class winner. Signed by two World Champions Eric Bostrom and Neil Hodgson. Yes I'm that guy with the soft toothbrush keeping everything perfect.
$9990 or feel free to make me an offer.
It's in beautiful condition. Carbon fiber everything, custom seat, full termi exhaust system, custom clutch. Comes with original red fairings, mirror turn signals and full carbon-fiber fairings. Passenger (pillion) seat and custom mono seat cowl. A box of other parts and presents.
New clutch, rear brake, Pirelli tires, belts, battery (the battery works!) I recently serviced everything (everything). NEVER DOWNED NEVER TRACKED. Always garaged stored.
Has just 12,000 miles!
2003 Ducati 999 Biposta - Goodies:
 Power Commander III USB with breather r-customized map $319
 Termignoni stainless steel asymmetric exhaust system kit: racing ECU, air filters and carbon fiber muffler cover $3500 (13.5 lbs weight reduction from stock)
 PauliMoto billet black anodized clutch cover $180
 14-tooth front sprocket, 38-tooth rear Vortex hardened aluminum sprocket $60,
 DID EVO 525 gold racing chain (48 links) (with riveted master link) $230.
 Ducati Performance billet aluminum sprocket cover, replacing the stock black plastic item $139
 Cycle Cat rearsets with matching shifter and rear brake pedals, red anodized features $525
 Fast-By-Ferracci raised clip-ons, polished finish $259 I'm over 6ft this helps
 Sergeant seat with Italian tri-color patch $299
 Ohlins steering damper, 20 click adjustable $450
 MotoWheels billet aluminum red anodized slave cylinder for improved clutch feel
 'Ilmberger' Ducati Corse carbon fiber with six coats of clearcoat (Nose, side fairings, air scoops $2395, front fender $303, with Ducati Corse badges $10, and Oil Cooler Cowling $180, Rear Hugger $100)
 Ducati Performance carbon fiber cam belt covers $250, C/F exhaust heat guard $40, C/F Key guard $55
 Ducati Performance Carbon Fiber/Billet aluminum quick release Fuel Cap $346
 Dzus fasteners are black anodized $15
 Zero Gravity dark-tinted double bubble windscreen $85
 Clear Alternatives integrated turn signal kit with LED lamps $81
 MotoWheels billet aluminum frame plug kit $64
 MotoWheels Billet Oil Fill Plug: 3 Star $14
 STM anodized red aluminum crankcase breather valve with K&N filter installed replaces stock black plastic breather $85
 BiPosto ABS seat cover with number panels
 Billet aluminum, red anodized fork preload adjusters $24
 Both clutch and brake master cylinders have had bleedable banjo bolts installed
 Tail Signed by both Eric Bostrom and Neil Hodgson in silver ink, clear-coated over
 Mirrycle bar end mirror $17
 Motorsports Machine Front and Rear Slider/Spools - $69
 Scorpio SR-i500sw Alarm with hand pager (yes a pager you put in your pocket) and Perimeter System with Ducati Harness - $324
 Stebel TM 80 Magnum Horn $13
