I'm looking for a 5-spoke front wheel for my '99 ST2. Beyond the 6-bolt rotor pattern, how can I tell if a wheel from another Ducati will fit or not?
I have a rear 5-spoke from an ST4s. Do the later model front wheels look the same as older wheels, or were there aesthetic or design changes?
Thanks for the help. Appreciated, as always.
A 5 spoker from a 748/996/998 will fit.
And any late model injected Supersports as well as many Monsters. You're looking for 25MM axle and 6 bolt rotor mounts. No changes in the front for looks either. All the Brembo / Marchesini 5 spoke cast fronts look the same. The very early ones had a different looking (meatier) hub, but the spokes and rim design are the same.
Thanks, gents.
So it sounds like as long as it's 17", 25mm axle, and 6-bolt rotor pattern, it should work.
