err...the Pit Bull steering head stand. You should have ordered both at the same time and saved some shipping!I bought the Pit-bull rear stand for SC, it's on it's way. So what front stand out there is recommended by you all? Thanks,.
I bought the Pit Bull New Front stand and it is great, BUT requires turning the front end to clear the front axle for removal. Since the SC bikes have a shorter 25mm head angle than the Superbikes. Still great though, because it allows you to do wheel and fork removal. To get full front end freedom you will need a Handy Industries Universal Lift with the V-shaped adapter plate (next on my list).err...the Pit Bull steering head stand. You should have ordered both at the same time and saved some shipping!
I like the steering head stand because you can use it to disassemble the front end. Admittedly it does interfere with my axle sliders a little, but not too bad. I never really understood those stands that go under the fork bottoms and can only be used to remove the front wheel. Why not just get one front stand that facilitates every possible operation?
