1 - 7 of 7 Posts
How tight should the front sprocket nut be and the rear hub pinch bolts,i have just got a 14T Front sprocket and would like to know so i can chainge it thanks :)
How do you get to 137lbs? Holding the brakes don't seem to be enough to stop the sprocket from creeping, I usually hit it good with the air impact. Just seeing how the pros do it.
When Harley's had chains, owners and several shops simply jammed the plastic handle of a screw driver between the chain and the top or bottom of the rear sprocket. Yes it ruins a screw driver, but it doesnt harm the chain or sprocket and its a one-man process.
I just tightened the rear wheel on an MV which required 220-240 nm. With the bike in gear and a friend on the brake it worked fine. Give it a try.
1 - 7 of 7 Posts
