Going to replace my sprockets and chain- going to order a new front sprocket retaining clip -but i see on the fiche at Stein Dense that there are shims behind the front sprocket (parts list below)- mine had none. Should I be trying to shim to eliminate some of the free play? There is a tiny bit and i think thats normal right? Also want to replace the screws that hold the plate- they show as M5X16 - should i be looking for a certain rating on those important little suckers?
shim sizes as listed on fiche-
part#
067016170 Duc Distanzscheibe 0.8
067016171 Duc distance gasket 1.0
067016172 Duc Distanzscheibe 1.2
part#
