1 - 8 of 8 Posts
I may need to remove the front cylinder head, so when removing and reinstalling will the valve lash be undisturbed and cam timing won't change if the belt is indexed to the same spot? Am I correct in thinking this? Never pulled head of Ducati.
Sent from my Pixel 2 using Tapatalk
Should not affect it but I’d go on and check at least, adjust if needed, if I was that far into it.
Why are you pulling the head? If you are doing valve work the cams will come out and every thing needs to be checked and reset. Good idea anyway while you are in there, and I would go ahead and replace the belts, check the valves on the V head. Do it all. Cheers
That would be correct sir. Maybe I should just jump ahead on the 15K mile service since I'm at 13k miles right now.
Definitely. You are close enough. No reason not to do 2k early. Better than tanking the whole bike apart again. Especially if you are that deep into it. Imo.
Discussion Starter #8
I ended up letting the shop do the repair, they had to remove head and send to machine shop for one of them plus a spark plug broke off on removal so that added to it. They did go ahead and do the service as well. They even hooked up the exhaust. Bike is back in my possession now and runs good although loud with just the stock muffler thing. May need to get something different to mellow that part out.
1 - 8 of 8 Posts
