1 - 7 of 7 Posts
Replacing stock fender for Shift Tech carbon piece. Looks like the rear of the fender uses a very small rivet(?). I was going to use a Dremel to cut the head & remove. Any tips or other methods to remove the rivet safely?
Discussion Starter · #6 ·
Yes it's a rivet, drill the head and replace.
Yes thanks. It was a rivet. Drilled it out and will replace with a small SS bolt from Ace hardware. The bracket holding the brake lines, however, is secured by a 7mm torx head.
That was a torx screw in my....
1 - 7 of 7 Posts
