Just before I put my front wheel back on, after having the tire replaced, my wife came out to the garage for a visit. Playing around with the controls she squeezed the front brake, closing the pistons on both calibers. I was able to carefully pry the left side open just enough to get the disc through, but when doing the same to the right side, I pressed in one set a little too far, forceing out the other to a point where fluid started to seep from behind the piston. I hope I didn't cause any damage. I equaled up the pistons, cleaned up the fluid and put the wheel back on. After aligning and torqueing everything to spec, I squeezed the front brake a few times. The first squeeze was a little soft, probably due to the tiny bit of fluid lose, or the pistons settling to the disc, but after that they seemed to be fine. I squeezed it a few more times and I don't see anymore fluid leaking. But I haven't ridden it yet. So my question is did I cause any damage to the caliber? Is there a seal behind the pistons that should be replaced? I would hate to go for a ride and have brake fluid leak everywhere.
Any help is appreciated.
The first squeeze after re-installing is always a bit soft as the pistons/pads settle to the disc. Usually it firms up after a couple of squeezes.
If you leave it a while, then squeeze again and it's soft again on the first squeeze, then you probably have some air in the system. Bleed it out.
There is a seal on each piston but I wouldn't think something like that would damage it. You could try tying your lever to the handlebar to pressurise the system overnight, then see if there's a leak in the morning. If so, then you may need to rebuild the caliper with new seals.
Agreed with the above comments. With older calipers I'll often push them in and out a few times to lube and loosen them up; no damage is caused.
That was nice of your wife to visit; too bad human nature took over and she had to start touching things.. haha
By pushing in the calipers you may have cleared bubbles from the ABS circuit - good time to do a bleed or ziptie the brake lever (firmly but not crazy) for a few hours, to get those bubbles out of the system.
