Changing fork internals on my Superlite means getting the front wheel off. Ran into a snag while trying to remove the axle. 14mm socket turns it from the right side, but it is turning the whole assembly with the speedo unit in the aluminum fork bottoms and then stops coming out after about 2mm. What gives? What's the trick?
Thanks in advance.
S
