Which ones do you recommend and where to buy?...
Eat lots of fibre???any other recommendations?
same here,, about 15 minutes,, the axle sliders just bolt on very easily.. the frame slider is just one step 'trickier' because you change the bolt as mentioned,, taking the existing bolt off actually held me up for about a minute because one side is a hex nut and the other is a allen keyTo install all 3 sets of sliders, it took me 15 minutes more or less. There is a long bolt where the frame slider goes and you just need to replace that with the supplied rod that comes with the frame slider. Very simple, very fast and highly recommended.
haha,, and milk!!!Eat lots of fibre???![]()
I get plenty of fiber already...Eat lots of fibre???![]()
I supported the motor with a hydraulic floor jack ,, but I dont' know if it was completely necessary as there are two other bolts that hold the motor. HOWEVER,, I did.I just got the Motivation frame sliders. The instructions say to make sure the engine is supported from underneath before replacing the mid-engine support rod. If and how did you do that? Also the original support rod seems to have a grease nipple on it. Any issues with replacing that with one that doesn't?
