1 - 12 of 12 Posts
I found a 1999 748. The guys has the fairins,tank,air box ,and velocity stacks off. He was gonna do the valve adjustments but his wife has cancer and doesn't have time to work on it. Here is the issue it has a backfiring problem on the front cylinder and he says the timing is set perfect. What is this problem,is it a big problem,and also what is a idea it might cost to fix. Also can I fix this or do I need a Mechinic? I am pretty good at. Fixing things but I want to make sure before I commit to the bike.
Thanks
Backfiring could be due to the exhaust valves being out of spec, which is probably why he was going to check them. You need lots of different size shims to adjust them, so probably better to let a shop do it!
I know all shops are different but what are we saying? 300-500$ range or 500$-1000$ range? Just getting a idea before I buy the bike?
For a valve adjustment alone? 500-1k...if not more. It might be cheaper if you just bring them the engine. Less labor cost if they don't have to tear down the bike. That's what I did.
Depends on the shop. If it was out here in the San Fran bay area I know a shoo that would do it for about $400 and have a 1-2 day turn around, but yes most shops would be closer to $1k+.
Sent from my Galaxy Nexus using Motorcycle.com Free App
Discussion Starter · #7 ·
What do y'all think? He doesn't have any records of the previous owner doing the matience but he did say it ran and run fine just has a backfiring problem. I am looking to spend around 3500 to get it running and new to the 748's I have heard the 1999 did have a few problems. Don't want to get into a bind or a money pit the will never run or cost more than its worth.
Every bike ran fine until a problem came up. Problem bikes are a gamble, just depends on how bad you want it and how much money you are willing to spend to fix it. Is everything else in excellent shape? Mileage?
Problems that might exist: Flaking rocker arms, rectifier wires melting, old timing belts.
Hard for us to give you an opinion with such limited information on the bike you are looking at. Can you post a link or pictures?
How far did he get into the valve adjustments? Curious if he took the cams out to look at the rocker faces. New ones are about $65 each. New shims will be needed if you replace any. How much is he asking for the bike?
I was wondering this as well. If you're already willing to put another 3500 into it just to get it running well, it would be worth it to add that 3500 to the over-all bike fund and find something nicer that has no current running issues.
Just a thought.
It is almost always more expensive to buy a cheaper bike... The problems always seem to keep coming up one after another. That's why they are cheap - not because you are lucky and getting some great deal! At least that is what I've seen time and time again.
1 - 12 of 12 Posts
