What is the best bang for the buck in an adjustable set-up?
The classifieds here, or on the Monster forums. Ebay of course. Check with Ed Milich at guzzipower.com, or with "Used Ducati Parts" on Facebook. I've been having increasingly good luck finding parts that people are listing for sale in the various Facebook groups as well.Where would you shop for a reasonably priced sp forks?
I'd second this suggestion as this is what I had on my SS. I started off with the Showa forks as my bike was an SP to begin with, but there is a design defect which makes it so the rebound damping and compression damping circuits cannot operate independently. I picked up a beat up set of GSXR600 forks off eBay for $60, a pair of RaceTech springs correct for my weight from a forum member here for $100 or so, the whole process was done in a day and I'm not known for my speed as a mechanic. I did a write-up with some pictures on how I did it in the SS forum.I’m going to guess it’s a pair of SP forks with GSXR internals and the correct straight rate springs. I bought the SP forks and used GSXR forks on eBay, then a pair of RaceTech springs and seals, total cost about $400. You can then use your stock wheel , axle, and speedo drive, or convert to the later axle and drive for little extra. Most of the other fork conversions leave you in an expensive situation with regard to the wheel, brakes, axle, and speedo drive. So, while you can buy Superbike forks reasonably, the rest of the conversion is expensive .
So you ran GSXR forks not Duc forks with GSXR inserts?I'd second this suggestion as this is what I had on my SS. I started off with the Showa forks as my bike was an SP to begin with, but there is a design defect which makes it so the rebound damping and compression damping circuits cannot operate independently. I picked up a beat up set of GSXR600 forks off eBay for $60, a pair of RaceTech springs correct for my weight from a forum member here for $100 or so, the whole process was done in a day and I'm not known for my speed as a mechanic. I did a write-up with some pictures on how I did it in the SS forum.
His write up with all the details is here: http://www.ducati.ms/forums/57-supersport/343186-sp-showa-fork-conversion-suzuki-internals.htmlSo you ran GSXR forks not Duc forks with GSXR inserts?
Wish I could have, but outside my skill set. Like Harry Callahan said, "A man's got to know his limitations." :smile2:I am doing my own work
It's an afternoon's work if you take it slow, no special tools or equipment required. With GSXR cartridges and racetech springs, the forks are transformed, probably on par with the aftermarket cartridges you have. $150-200 worth of parts if you already have the SP forks, double that if you don't, gets you a nice set of fully adjustable, reasonably compliant forks. The mod is not as bad as you make it sound. Out of curiosity how much did your cartridges cost?Gixxer adjustable fork cartridges are cool and all but from what I've read it sounds like a lot of work dickin' around to make them work with your stock forks.
