Senior Italophile
The large hex at the top of your forks turn clockwise to add pre load counterclockwise to make em softer.
Static sag on the front should be around 1 1/2". If the front dives too much with this amount of static sag, increase compression damping. If you weigh much more than 150-160 lbs you might need stiffer springs.
Joe
