1 - 3 of 3 Posts
Is a fork rebuild doable by the DIY'er? or are special tools needed? Anywhere have a step-by step procedure?
Thanks,
S:)
I did my stock, adjustable Showas on a 96 900SS/SP a few years ago. From what I can remember, I made a couple of special tools, but not that special. I cut a slot in a washer to keep the spring compressed at some point. Also, I got a piece of PVC, I think, as a seal installer for the assembly.
A spring compressor would have come in really handy as that part was a little tricky. If I do it again I'll buy one or build one. I've heard of people making a spring compressor out of 2X4s, allthread, and hardware.
I put different springs in and RaceTech Gold Valves and I really like the change, though probably mostly due to the springs.
Jake
I've done mine. Pick up the haynes manual. It explains how to tear down the forks. The slotted washer trick is also explained in the haynes manual.
1 - 3 of 3 Posts
