I have to rebuild my 749 forks because of a seal leak. It's nothing major, but it's a good excuse to service them. I have no idea when and if they have ever been done before.
I have new seals, dust wipers, and bushings on order. I'll be using Maxima 5wt fork oil which I've been using in the ST to good results.
I'd like to verify the correct oil level. The bike is a 2003 and the factory manual I have is from 2005 which says 104 mm. The Race Tech website says 110 mm for the 2003. But, if you look at 2004-2006 Race Tech says 90 mm. To the best of my knowledge, the forks are basically the same throughout the years other than if they're TiN coated or not. I'm not sure which measurement I should be using. Does anyone have their experience to share?
Thanks.
Edit: I should also note that the factory level looks like it's without the spring in and the Race Tech level doesn't say.
Thanks.
