Morning all
Just curious as to the likes of the DP footpeg blocks, can you still run the rubber top on your footpeg with the DP scrubber block?
I prefer my rubber tops but not sure if I could still run them with the scrubber blocks underneath.
Anyone have this knowledge please let me know, many thanks.
Morning all
I have seen it done, but I have not done it as I like the grip on the metal teeth, I think it just requires longer bolts? Aloha Alex
I did it.. It took longer bolts, and it seems like I had to drill a couple of extra hole but I dont recall. Either way the awnser is yes but it will take a little work. You dont have to be a ducati mechanic or anything like that though.
Cheers for that guys, will look into it now I know it can be done without too much drama, wonna save the bottom of my pegs so better do something.
