I gots a question: On well, every bike I've owned, the front brake & clutch reservoirs have always been level, if not with the bars in "straight ahead" position, at some point in the bar range. My idea was this let you easily read and adjust level of the fluid. On my MTS ('16 S) both tanks are angled down toward the front of the bike. There's no point in the range of the bars that this angle goes away. I thought that maybe they were just misadjusted, but I loosened the mounting screw on the clutch side, and it doesn't rotate. It's like the mounting tab is indexed into the bracket. I haven't take it apart to look, but are they installed wrong? I'll try to post pics if I can't sort it out.
Thanks for the help!
