Have any of you made some modifications to jump-start an ST without removing most of the front fairings?
I found that AntiGravity makes a short pigtail for use with many lithium jump start packs, and picked up a couple, after an earlier attempt to build my own.
It's important that these leads are short due to the high currents involved in jump-starting, and tradeoffs of fitting large gauge wire. I think there is enough length to feed through the black plastic trim in the right-side main fairing.
It would probably be easiest to tape it over top of the black plastic trim insert/scoop. Should I go through the trouble of hiding it inside this piece, and if so any recommendations for fitting? I wasn't sure if this is a heat vent or active aero at speed.
Cheers!
Cheers!
