I know it's second hand, but it was inspected fully by the dealer and a full 2 year warranty agreed.
Spotted the cable from the preload adjuster has worn through its outer sleaving and the yellow coating on my rear spring
Is aligning pipes, wires etc just something Ducati can't do?
My 2013 pikes peak front brake line wore through the front fork anodising, twice before they cured the issue
My 2016 pikes peak worn through preload adjuster cable as above.
Also I see the front mudguard has been replaced and the new one has a patch of what looks like venture shield stuck to it because the front brake cable touches it!!!
