1 - 12 of 12 Posts
Well, here it is. 06 749 Dark. Been riding it for a month now.. She was a basket case when I got her. Front wheel was cracked, rotor bent, frame bent. most of the body work was torn off. Gauges were broken, missing keys. Could not start it nor did I want to, until i adjusted valves and changed belts.
Rim and rotor were fixed at m.c wheel $200.00
Frame was straightened at GP Frame and wheel, up in napa california $450.00
Gauges baught on ebay $900.00
Frame powder coated at lone star powder coating $200.00 (Satin Black)
Body panels were baught on ebay, Then I painted them with Dupli-Color Bumper Black Rattle can Paint.
Trim pieces were done at signature plating (polished Black)
The Ducati lettering was cut on a CNC, and is made of .016 thick aluminum
Total cost of bike was about 6k
Nice restoration. It's nice to see another Ducati not hitting the Parts Dismantler's shop. I enjoy bringing bikes back from the dead also, great satisfaction.
Cheers,
Mark
Discussion Starter · #7 ·
Tank pad
I work in the aircraft field. so I used this stuff that we have in stock called 3m scotch weld neoprene contact adhesive. I also baught some stuff from autozone called 3m molding tape. I used it to hold the ducati lettering with. That might work as well for you..
Nice job. I like the black frame. Did you laser the lettering out or water jet it?
How much did you pay for the bike?
1 - 12 of 12 Posts
