Thoughts on this one, please.
Late last year my 2000 750SSie (24,000 miles) developed an odd FI problem. If you set the idle high enough that the engine would run, then the first time you revved it over about 3000 or so it would "hang up" and not come down again - just "idle" at 3000 rpm. I was able to confirm that it was not caused by the throttle hanging up in any way - both butterflies closing normally.
I messed with it quite a bit trying to solve the problem based on instructions in the factory manual, but eventually came to realize that I just didn't have the tools needed to set up the fuel system properly. So, I took it to a good dealer, and they did a complete setup of the FI, including TPS and all that (actually, they went through the whole procedure twice, since it was so far off - "Sir, someone has really been monkeying with your fuel injection"...Err, really? Hmmmm...). Very expensive.
Anyway, at least the bike is rideable now, but it still has quite a long pause as the revs come down when you pull in the clutch - it still "hangs up" at about 2500 rpm, but only for 2 to 3 seconds or so. I think it is worse when the engine is completely warmed up. Another symptom is that If you open the throttle in neutral, it is impossible to hold a steady engine speed in the 2000 to 3000 rpm range - it will either rev higher than that, or fall down lower.
Any suggestions? I am reluctant to pay another mechanic (or the same one) to look at it again, without any idea about what could be wrong. Otherwise, I am likely to just get a bike that runs exactly the same, and be a couple hundred bucks poorer.
Other info - it has a lightweight flywheel (yoyodyne), but the bike ran well for quite a while after I installed that. Immediately preceeding the problem I did a belt change, but I have checked and rechecked the timing, so I don't think that is the issue. I think the mechanic said he had found a vaccuum leak in one of the rubber TB boots, but had fixed it.
