I am having difficulty understanding what are the compents required to fit FCRs to a carby 900 SS.
I have been trying to find a photo of the components but so far nothing that helps.
Here's what I have worked out so far. If you can correct me and fill in the gaps that would be appreciated.
Typical dual kit includes
The other option is to mount two singles in which case you need:
- Two carbs, operated by a single common throttle mechanism
- Two bell mouths
- Throttle cables,
- Throttle,
- Two Spigots, (Not sure where these go and what they do?)
- Two airbox adaptors (what do these look like?)
- K&N or BMC air filter (which is fitted to the adapted air filter box).
- Two single carbs each operated by a separate throttle mechanism
- Two bell mouths
- some sort of linkage to connect the throttle mechanisms of each carburettor?
- Throttle cables,
- Throttle,
- Two manifolds
- Two velocity stacks?
- Two cone filters.
