My phone uses to fast charge using the USB SAE, but ever since it rained it has been slow. The USB cable was fried so I replaced it. I also have another SAE cable connected for a trickle charger and another for a ground because I fried the ECU ground.
I can't tell what causes the slow charge. Whether it's all the lines I have connectes to the battery, or the SAE USB is just bad.
What do you use to fast charge your phone and have you had any issues?
